Temperature gauge stopped working
Posted: Thu Jul 26, 2007 9:52 am
Hi everybody,
This weekend I was under the hood tightening the water pump/alternator belt which made the chirping sound go away (yes the belt was loose, not worn out). When I was done I noticed that the temperature gauge is no longer working. I'm assuming that I bumped something while I was under there but I'm not sure where to start troubleshooting. There appear to be two sensors in the thermostat housing one with a single wire and one with two. I can't recall off hand which one is for the temperature gauge or what the other one does. I checked the wires for soundness and for dirty connections but I'm not sure what to do next. Is there a simple way to test that the sensor is working?
On an only slightly-related theoretical note, do you think that if a person were to overheat an SD22 without knowing that the oil pressure would drop enough that the DPC would save your ass before major damage occurred? I have not done this and wouldn't count it but this situation made me wonder if it would work like that. Thanks for the advice, you guys are the best.
