Page 1 of 1
Chirping Crickets
Posted: Thu Oct 04, 2018 8:34 am
by plenzen
Been pretty quite in here for the past while.
Just sayin.
Re: Chirping Crickets
Posted: Thu Oct 04, 2018 4:38 pm
by ziper1221
Yeah, it is. I'm still working on my 720 with the smoke issue, I disassembled, honed one cylinder, and reassembled, but I put one connecting rod cap in the wrong way. The motor turned over fine by hand but the first time I cranked it with the starter it locked right up. The cap and crank were both galled. I really don't want to put any more work into this motor, seeing as how many problems it has given me so far, so I'm contemplating if I want to do an engine swap or junk/part out the truck. The body is rather rusty. I'm really kicking myself.
Posted: Tue Oct 16, 2018 8:51 am
by plenzen
That's kinda crappy news. How bad is it "galled" ? Any way you can get it polished out ?
Posted: Fri Oct 19, 2018 11:21 am
by ziper1221
A bunch of metal got smoosh around here:
https://i.imgur.com/3ubXw2e.jpg
I have another crank that just has a bit of surface rust and would be easy enough to fix up, but... I never conclusively fixed the smoking issue, and at the rate of carbon buildup I doubt it would've made it more than 10k miles. car-part.com has a bunch of Z22/24s around but the closest diesel is 1000 miles away and not cheap.
Posted: Tue Oct 23, 2018 5:00 pm
by plenzen
Not sure where you are but perhaps check some marinas. They may have an old CN4-33 lying around. It's the same thing.
Just a thought
Posted: Sun Jan 13, 2019 12:42 am
by waynosworld
I basically lost my computer for a while, it updated in September and that Microsoft spyware called Cortana on my Windows10 system and that screwed up my computer ability to process photos, it updated 2 more times and each time after removing the Cortana I could relearn how to do photos, well the last time it updated they made it impossible to remove Cortana, when I realized I could not remove it I hit the computer so hard it had to run a diagnostic to start up again, I shut it down and didn't start it back up for 9 months, I used my old computer with Windows8 till the computer guy called me about cleaning out his gutters, so I talked to him and then took the computer to him when I did his gutters and he put Windows7 on this computer, it's a way better system and everytime it updates I do not have to relearn how to do photos.
I didn't use my old computer for much other than to see my emails as if I tried doing photos the CPU would overheat and Windows would get corrupted, so mostly it was in sleep mode, I got so used to just ignoring the computer I just forgot about this site when the good computer was working again, I was doing other stuff for several months that was not diesel related.
I just updated my 1980 Datsun 720 thread in the user rigs section.
