Nissan CABSTAR / Atlas F22 Engine
Hello,
i bought a Nissan Cabstar F22 with 51kw and want to upgrade the engine, because i need torque. I will use it as a recovery truck.
I thinked about swap the engine with a TD27 or a TD27 with Turbo. But im afraid if the differential and the transmission can bear this torque.
I also read about Turbo upgrades, but can the TD23 engine bear the pressure ?
Thanks for you help.
Cheers
dodo
Cheers
dodo
What part of the world.
TD32 cabstar.
has the gearbox got a hand brake on the drive shaft.this is an option and if the original box hasnt its a normal car/pickup box.if it has it should be beefy.I like the auto option for towing so I would look at any ute or van motors.nissan diesels very slow without a turbo.the TD23 with cood cooling and oil cooling for the pistons would be good with a turbo for a few years.
the only book i have for F22 is 1988.
TD32 had a banjo H190A or a H233B.the 190 is a car diff and copes with 3.0 engine.the 233 ins the bullet proof patrol diff that you be able to get up grades for.the TD27 has a C200 option that you get with high powered cars and the pickups.
My choise would be a TD27T out of a pickup or a van.i think the van engine is the easiet conversion and some have a water to air intercooler.
lots of TD27 around so i dont think its worth will changing to a V6 or V8.
TD32 cabstar.
Hello,
first THANKS for you help.
i am from AUSTRIA/Europe
I looked my papers and the Engine Code is TD 23-040 151
The car is really a working horse. but its very slow.
Yes there are many TD27 engines around.
There are many different TD27 engines. Which will give the best result to me. TD27Ti ? i also need a low consumption
http://en.wikipedia.org/wiki/Nissan_TD_engine
I will also look for a Patrol Y61 differential.
Cheers
Cheers
http://oldjapanesecar.proboards.com/index.cgi
a gent on here is from austria-he has experience with you bizzar diesel road laws.he has said that you can drive these old cars into city area as they are dangerous.if you frive past a tree it might die.[antigreenhumour ] and as it hasnt got stability contol and air bag you may not be able to steer it.
the numbers are the engine number
TD 23 type -040 151 manufacture serial number.IE
on the japanese build plate will be a TRANS-code IE RSW571B
and final drive code HC43 [H190B]-C?43[salisbury] RC43 [IRS].the number is the ratio the letter is the type.
organist the engine first before you get a diff the original will do if your not into burnouts.LSD diff is hard to find for the small axle.
RD28 patrol often have a 4.3:1 axle.
TD27T electronic made in spain may be your option due to you conversion laws.its fly by wire etc etc.in australia i would throw the eletrics in the bin and fit an older injector pump.intercoolers are good.
jap imports are common here so that would be my best option.the VAN has a square sump my guess is you truck is the same.the van has low profile-the inter cooler hangs off the back.
other options are the newer larger 3.0 diesels-small van LD20T/CD20T
.if there is room behind the cab a TD42 patrol-civillian engine is cheep grunt..the larger cabstars also use an ED33-FD35-large old 4 cyl diesel common put into early landrovers from the H40 cabstar.
do a google==Nissan F22 workshop manual.
lots around including online.what you have to look for is they dont list TD23 as it is an update on a SD23.you may need a later manual that covers the Z engines.
the book at work only covers a few updates on the ED33 civilian.
yahoo japan also is good for japanese language manuals.f22 might be rare.
http://www.pitstop.net.au/view/manual/f ... IAN%7C1892
http://www.marque.com.au/scripts/BooksB ... san&Type=C
Users browsing this forum: Ahrefs [Bot] and 2 guests
