NissanDiesel forums
http://nissandiesel.dyndns.org/
97 UD 1800 only idles dies after first rev wont accelerate?
http://nissandiesel.dyndns.org/viewtopic.php?f=13&t=3753
Page 1 of 1
Author:  nihad [ Sat Sep 17, 2016 12:58 am ]
Post subject:  97 UD 1800 only idles dies after first rev wont accelerate?
I own a 97 UD Nissan 1800 6.9 6cylinder turbo diesel it has the Zexel bosch pump and when i get it running it will idle but soon as I rev it the first time it dies right away.. I also cant drive it anywhere because of this problem? what do i need to check first i have plenty of diesel in the tanks. I have noticed if I rev it and keep spraying in starting fluid at the intake tube it will keep going.
Author:  Nissan_Ranger [ Wed Sep 28, 2016 5:20 am ]
Post subject:  Re: 97 UD 1800 only idles dies after first rev wont accelera
I believe that the fuel feed to the injection pump is impaired. I would check charging (lift) pump function & pressure, fuel filters, and for kinked or blocked fuel lines.
Page 1 of 1 All times are UTC - 8 hours [ DST ]
https://www.phpbb.com/
