Bleeding air from injector pump
Hi, Is there a blld screw on the injector pump on a ld28. I ran it out of fuel and are having trouble getting the air out of the system. Thanks Pete.
Does anyone know where I can source a seal kit for the injector pump?
Re: Bleeding air from injector pump
If there is a Bosch service center in your area, they can supply you with a seal kit (and most likely any other IP parts) if you tell them the numbers on the side of your IP.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 3 guests
