My sd22 boat engine starts and runs fine in neutral at all rpms. Soon as I put in gear it dies even at 1400 rpm. Thoughts?
Also my electric fuel pump is very warm.
Thanks!!
Sd22 does under load
Re: Sd22 does under load
Does it rev and then start dropping rpm until it dies or does it just die abruptly?
I would say change out the fuel filters first, if it doesn't have a pre-filter then I would check the screen in the lift pump banjo fitting on the bottom of the lift pump.
Ldog
I am still hoping for more thoughts on my issue. I replaced all filters, replaced the electric lift pump, replaced the cutoff solenoid. replaced the mechanical fuel pump. Bled carefully in sequence. Engine starts, runs up to full rpm in neutral. When in gear, zero increase in rpm. All cables OK. Lift pump pulls from tank freely. No smoke. Air cleaner clean.
Is the prop shaft seized in the stuffing box? Maybe have 3/4 of a mile of nylon line wrapped around the wheel?
I know this is a bit late and you probably have it figured by now.
Users browsing this forum: No registered users and 44 guests
