NissanDiesel forums
It is currently Sun Jun 24, 2018 9:12 pm
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3, 4, 5
Author Message
 Post subject:
Post Number:#61  PostPosted: Sun Sep 07, 2008 4:10 pm
Offline
I've been going with the stock set-up less the OFV valve and have not had a problem since I punched it out. YMMV
N_R
_________________
Top
 Profile
 Post subject:
Post Number:#62  PostPosted: Sun Sep 07, 2008 11:28 pm
Offline
Thanks N R. The problem with that is you will not create a pressure in the IP fuel chamber as it is open to the return line without a restriction. Yes it will work and is the set up on many a diesel of old I've looked at. But, a little pressure in the IP fuel supply line (1-2 bar) is good for stability and air pocket release I'd have thought.
I think one of the reason's Philip modified his set-up was because he thought he had too high a pressure. It wasn't clear to me from the postings as to whether the problem was caused by a faulty OFV or the updated lift pump he had. I wonder if you could modify the OFV with a slightly larger orifice, this should bring the pressure down ?
Top
 Profile
 Post subject:
Post Number:#63  PostPosted: Sun Sep 14, 2008 4:40 am
Offline
I found this thread and though it would be good to reference it here:
viewtopic.php?t=1153
seems Philip did have an answer after all :D
Top
 Profile
Post Number:#64  PostPosted: Tue Jun 14, 2016 10:00 am
Offline
I think the air comes from the fuel discharge line, that goes back to the tank from the filter housing; it is the only line that is open to the atmosphere, as it dumps in the tank with no line into the fuel. I have connected the return line and the discharge line from the filter housing, and pluged the two ports on the filter housing. I have been able to drive with the tank below 1/8th, and previously it would quit if half or below. So far so good. I am now unable to reduce the fuel pressure form the delivery pump, but so far have not blown any hoses.
Top
 Profile
Search for:
Jump to:
