WTB: LD28 Industrial style oil pan
LanceVance
Post by LanceVance »
Looking for an LD oil pan like the one pictured below. This is an industrial (forklift, pump) application oil pan that has two protrusions on the sides, increasing oil capacity. If anyone has one that is in decent shape that they wouldn't mind giving me a good deal on I'd love to hear from you. Would need to be shipped to zip code 79938.
Text preferred nine1five -383- 75SixSix.
Thanks much!
-Marcus
tfm1066
Re: WTB: LD28 Industrial style oil pan
Post by tfm1066 »
I had onebut let it go i have the front sump style if needed, but it won't work in a diesel Z.
LanceVance
tfm1066 wrote:I had onebut let it go i have the front sump style if needed, but it won't work in a diesel Z.
Afraid I need the mid/rear sump style. Thanks though!
If anybody has any suggestions where I might find one I would be very appreciative!
LanceVance
Still looking!
LanceVance
Over 200 views and nothing yet :|.
Surely someone has one of these tucked away in the corner of their garage gathering dust?
LanceVance
300 views bump! :?
Been thanked: 1 time
May end up being a "quest" for sure.
Probably already tried this but, perhaps reach out to some forklift repair places ? Not sure what other applications used this engine in an industrial application.
Good luck. !
LanceVance
plenzen wrote:May end up being a "quest" for sure.
Good luck. !
Thanks!
Reached out to a few forklift parts suppliers, no luck so far. This is a back burner project for now, but I expected some difficulty finding one of these pans so I've posted in quite a few places. We'll see what turns up... or doesn't!
Was thinking more of the places that do forklift repairs.
buddabeast
Post by buddabeast »
I may have one... will check this weekend.
edit: O wait I just saw you are in Canada...
Duaneclark
Post by Duaneclark »
Not sure why you need the added capacity, but other ways to accomplish the same thing would be, just change your oil more often, and, or, add an engine oil cooler. If you're running this type of engine extra hard, you could go to a straight-weight engine oil, like 30W.
Duane
LanceVance
buddabeast wrote:I may have one... will check this weekend.
Not in Canada brother, I'm in Texas. Curious to see what you've got.
LanceVance
Duaneclark wrote:Not sure why you need the added capacity, but other ways to accomplish the same thing would be, just change your oil more often, and, or, add an engine oil cooler. If you're running this type of engine extra hard, you could go to a straight-weight engine oil, like 30W.
Just looking to build from the very best possible start point, while using (mostly) factory parts. L28ET oil cooler, high pressure/volume pump, glyptol in the block... this oil pan is just part of the recipe.
I could easily make it using one of the rear sump pans I've got, but the hunt makes for a more satisfying journey.
