Page 2 of 2
Re: Picture test
Posted: Mon Apr 28, 2014 12:54 pm
by plenzen
I was thinking more of using up space.
Re: Picture test
Posted: Mon Apr 28, 2014 1:42 pm
by asavage
[shrug]
Storage is dirt cheap, Paul. I have a pair of mirrored 3Tb drives on the NAS that backs up the site, and currently just shy of 1Tb devoted to the online webspace.
It's gonna take a while to fill that, maybe as much as three years. AHAHAHAHAAHAHA!
Re: Picture test
Posted: Wed Apr 30, 2014 7:04 am
by asavage
Posting pictures using the forum in 2014:
A picture is -- first -- a file that you attach to a post. A file attachment.
First, scroll below your Compose window and find
Upload Attachment
- Upload_Attachment_01b.png (6.73 KiB) Viewed 62813 times
Select "Browse", choose a picture file, then select "Add the File":
- AddTheFile_01b.png (8.42 KiB) Viewed 62813 times
A progress bar dialogue will pop up while it's uploading, and it might take a while to upload to the server:
- UploadInProgress_01b.png (12.07 KiB) Viewed 62813 times
Now the file is uploaded (attached to your username).
To insert it in your post, use the "Place inline" button that's now directly under the Compose window:
- PlaceInline_01b.png (2.38 KiB) Viewed 62813 times
That seems to be the method to insert pics in a post. I admit, I haven't explored this much.
Re: Picture test
Posted: Wed Apr 30, 2014 7:55 pm
by waynosworld
Trying to attach a few files, well I tried to attach 3 of them, but only the last one appeared.
Re: Picture test
Posted: Wed Apr 30, 2014 8:01 pm
by waynosworld
Second try, 2 this time.
Re: Picture test
Posted: Wed Apr 30, 2014 8:03 pm
by waynosworld
OK, it takes a long time for them to load, so I am assuming they are large files, I don't know how to re-size them.
Re: Picture test
Posted: Thu May 01, 2014 5:27 am
by plenzen
My test for posting multiple photos of different sizes and also to see where the "file comments" show up in the posting.
Yes
Size does make a difference. ( nyuk )
The close up picture is 1.14mb the other is 191 kb
The smaller one uploaded or attached in 2 seconds or less the larger one took about 20 seconds.
As Al has pointed out. The larger one will have more detail should you want it.
On one other forum I am on if you were to attach a file of 1 mb the screen shot would be massive and the admins on that site ask that you remove it and resize it. I must assume that site is using different software etc.
(Al will undoubtedly know why)
This is much better for the detail that some may want and able to zoom in.
EDIT:
From the time I pressed submit to the time they showed up on the site was about 10 seconds.
Re: Picture test
Posted: Thu May 01, 2014 9:17 am
by asavage
If we have a lot of traffic here, that might sway me to impose a size limit.
I think the pagination is set to something like ten posts per page as a default, and that you can change it on a per-user basis (ie YOU can change how many posts show per page for YOU).
If you get a lot of pictures per post, and a lot of posts per page, it can take a long time for the pics to load, and some older browers will "jump" the page around as the pictures load, which has the effect of not being able to read anything until all the pictures have loaded. That's annoying, and another reason why some admins set a pic size limit (and a number of pics per post limit).
I'm not going to go there until it becomes necessary. Storage space is not a problem. Load time or bandwidth might become a problem, but it's not now.
There are a couple of automated tools that can resize uploaded pics as they are uploaded, so there is not a large file stored, but that negates the benefit of being able to zoom in.
Re: Picture test
Posted: Fri Mar 15, 2019 6:20 pm
by waynosworld
Test photo
- fingers_crossed.jpg (20.53 KiB) Viewed 61363 times
Re: Picture test
Posted: Fri Mar 15, 2019 6:23 pm
by plenzen
I can see it.
Re: Picture test
Posted: Tue Aug 01, 2023 12:59 pm
by waynosworld
Thankyou for cleaning up the forum.
Re: Picture test
Posted: Tue Aug 01, 2023 1:43 pm
by asavage
waynosworld wrote: ↑9 months ago
yvw
