Fuel Mileage...
lww
Fuel Mileage...
Unfortunately, I'm stuck with the 3-speed automatic tranny... In my search for better fuel economy, I've found the Kumho Ecsta ASX comes in a 205/65/15 which I've just ordered from TireRack.com. Paired with my "new" 1985 15" 200SX Turbo 32 spoke wheels should give me about 5% more diameter and a litte more fuel economy.
Anyone have any other ideas for improving fuel economy on the LD28 powered 1st gen Maxima?
Cheers,
LWW
Cheers,
LWW
diesel-man
diesel-man
lww
lww
diesel-man
lww wrote:I assume that's with the stock 14" Maxima wheels? The 200SX 15" wheels have -15mm offset so they bring the tires in from the fenders and allow you to get larger tires on without rubbing the fenders or the springs at least up to 205/65/15's.
Any other ideas?
Cheers,
LWW
My 225/75r14 are 1.795 taller than your tires. Goes 5.5" further each time the wheel turns one rev.
It has been working for me since 1986. My experience vs....?
HowlerMonkey
lww
I'm not arguing with your statement, just that I prefer not to run a staggered setup. As I mentioned in my post two days prior to your reply, a 205/75/15 might be doable and it's within 0.6% of the diameter of your 225/75/14 without the additional 20mm cross section so it would probably fit on the front as well as the rear giving the car an even stance and making tire rotation a simple exercise.diesel-man wrote:lww wrote:I assume that's with the stock 14" Maxima wheels? The 200SX 15" wheels have -15mm offset so they bring the tires in from the fenders and allow you to get larger tires on without rubbing the fenders or the springs at least up to 205/65/15's.
Any other ideas?
Cheers,
LWW
The Kumho Solus KR21 is available in 205/75/15 for only $75ea. from Tire Rack. Looks like the 205/65/15's are going to get swapped onto my wife's Subie!
Thanks for the inspiration!
