what size turbo for a ld28?
alramone
Post by alramone »
i've got a stock ld28 in my range rover classic. i really need more power so i'm going to turbocharge it.
what is a good sized turbo to use?
i'm thinking that getting one from a same ish sized turbo diesel engine would be a good start. td27t turbo or maybe one off of a mitz pajero or isuzu etc.
but... i have a good used gt28r roller bearing turbo off of a s15 200sx 2litre 16v engine. it's roller bearing so should spool up quickly, but it's good for 300+bhp on a high reving petrol engine and i only want 150bhp?
so, if i sell the gt28r what should i be looking for?
240ZD
Post by 240ZD »
Smaller turbos seem to be better for these diesels, especially since you're not going for mega power. The quick spool at lower rpm is exactly what you need.
alramone
Post by alramone »
i've got hold of a 280zx turbo manifold and turbo. i could just use this turbo, but is there a good one/size to look out for?
240ZD
Post by 240ZD »
That's a T3 turbo. Should be just dandy.
dieselfink
Post by dieselfink »
i am most definately happy with my gt28r...amazing spool times great sound
83 maxi, ld28, fire ringed, copper head gasket, 5 angle valve job, ported head, coustom turbo flange, gt28r ball bearing turbo 20psi of boost@1250degrees, timing bumped, full load screwed, cold air, straight piped, 308k miles..for now
st jacob
Post by st jacob »
In my opinion small turbo will be better for you and i think it can give you more benefits.
jacob
