first gen and second gen interchanging parts
OK so I went to pull a part today in search of interior parts and found two second Gen maximas both with just as ragged interior that mine has....
....but did get two brake calipers that I needed along with a grille headlights a wingding back tail lights and interior out of a Mercedes long story short the calipers and interior are the only thing that's going to work with a little moding long story short what the heck will interchange with other Nissan's on these things....went to oreillys and couldnt get a carrier bearing or a u joint!!!!!were do y'all find parts for these things????
83 maxi, ld28, fire ringed, copper head gasket, 5 angle valve job, ported head, coustom turbo flange, gt28r ball bearing turbo 20psi of boost@1250degrees, timing bumped, full load screwed, cold air, straight piped, 308k miles..for now
The carrier bearings are readily available, E-Bay, Rock Auto, most parts stores. They must have used them also in more popular applications. The drive shaft is kind of a replace the whole thing when a U-joint is bad. There is an internet source for a company that will sell a new one-piece driveshaft for the Maxima, but I have a 1984 gasser with a (looks like) new one piece driveshaft, and it vibrates badly at certain speeds, there is a reason Nissan had a two piece driveshaft. I don't see why a driveshaft rebuilder couldn't weld new ends with replaceable u-joints onto the original, but this is expensive.
Duane
