Size fuel hose with banjo fittings
Anyone out there know what size fuel hose and banjo fittings go from the fuel filter to the manual feed pump on the sd 22 engine. Any help will be greatly appreciated. Thanks.
Re: Size fuel hose with banjo fittings
I will try and find that info for you if someone does not come up with it first
You just looking for diameter size or do you need actual size of banjo fittings and bolts with thread sizes etc ?
Just a thought here but
try checking with a diesel fuel injection service depot and they may have some lying around.
I really need the entire part including the banjo fitting and hose size. The nissan parts zone has something but I'm not sure if it includes the banjo fittings. Unfortunately I'm not near the engine to get these measurements. The engine is on my boat which is in another country. Any help is greatly appreciated.
