New alternator with pump, plus starter - LD28
240ZD
Post by 240ZD »
Hello all,
I have a brand new alternator with air pump and a used starter available for the LD28 diesel.
Price: SOLD shipped to USA, OBO
Thanks!
-Sam
Has thanked: 9 times
Re: New alternator with pump, plus starter - LD28
I wonder if that starter would work on an SD25, I know the alt will and your so close to me, the angles look right on the starter, but the gear area is different, but that doesn't mean it will not work.
Does anyone know if the LD and SD share starters?
240ZD
Post by 240ZD »
I'm not sure, but it seems they are different. Here is a thread about the SD22/25 starters:
http://nissandiesel.dyndns.org/viewtopic.php?p=11072
If you or anyone is interested in just the starter or alternator, then feel free to make an offer. I've moved on into the realm of the CD17! :]
I think the LD starter is on the other side of the engine ?
I seem to recall that from someplace so it would not be indexed properly.
TheDieseliminator
Post by TheDieseliminator »
Do you still have both parts?
*occasional daily driver*
Softaildeluxe05
Post by Softaildeluxe05 »
How's it going, I was wondering if you by chance know the bolt size for the bottom bolt of that alternator? Somehow mine fell out while driving... I noticed the belt extremely loose and found that that bolt was missing I have no clue how long I drove with it like this. But it would be a great help if you knew this bolts details. Thanks alot!
1982810maximadiesel
Been thanked: 1 time
Post by 1982810maximadiesel »
240ZD wrote: 9 years ago Hello all,
Thanks!
-Sam
Do you still have any
Parts for the ld28
