CN4-33 Damper Plate needed
crzhors
Post by crzhors »
I'm looking for a Damper Plate for my CN4-33 adapting to the Borg Warner 71C trans, 9 1/2 dia.,4- 5/16 bolt holes,6 springs,26 spline.
any hints? :?: JD
pbknowles
Post by pbknowles »
Since you have the marine version, the flywheel housing and drive plate conform to an SAE specification and should not be Nissan specific. If you look at this: http://www.marathonelectric.com/generat ... saedim.pdf
it looks like you have an SAE 7-1/2 housing. That broadens your search options since now all you need is an SAE 7-1/2 drive plate for a BW drive. This standard is common on industrial and marine applications so that any engine will bolt to any drive or pump or generator or whatever.
SD22 powered '85 Chevy S-10
pbknowles
Post by pbknowles »
BTW I Googled your Challenger 40 and she sure is purty! I sail a Quickstep 19 on lake Michigan..
crzhors
Damper Plate
Post by crzhors »
Thank You PB, Its a good day when I learn something,like pieces of a puzzle, Maybe I can get the price of this plate down to earth, as soon as you say"marine" it becomes a $395 friggin specialty! Forklifts,Generators,Pumps... Back to the hunt!,
THNX, JD
