eBay (KS): 1980 SD33 TD
Auction 270126862515, ends Jun-10-07 09:38:31 PDT
I'm selling a Nissan Turbo Diesel engine that came out of a 1980 Scout II. It has one cracked piston, the reason it quit running. I do not know the condition of the others, but the cracked one was obvios and it was pulled out of the engine. It is the short block, pistons, crank, rods, motor brackets, oil pan, water pump, fan and the parts on or near the engine in the picture only. Must be picked up, located in central Kansas. Must send half via postal money order or pay pal within 24 hours of the end of the auction with the rest payed at pick up. Please do not bid if you can not pick it up.
Seller has the head for auction separately, Auction 270126858281
I'm selling the head off of a Nissan Turbo Diesel that came in a 1980 Scout II. The head comes with the valve cover and rocker shaft. It has the small superficial cracks between the valves and off some precups, but was magnafluxed and it checked out okay. Postal money order or pay pal.. Buyer pays shipping and hadling, I will get a quote to your zip after the auction is over.
