1982 Datsun 720 Pickup King cab - Diesel! WVO! - $2000
Reply to: sale-366252588@craigslist.org
Date: 2007-07-03, 11:32PM PDT
I have great little Diesel Datsun that I converted to burn waste veggetable oil (WVO). Unfortunatly I forgot to check the oil on a long drive to and from southern Oregon and it burned up all it's oil, and the piston rings need to be replaced. everything else should be good. it still has 400psi compression in 3 of 4 cylinders, and is already converted to WVO. It took me to Alaska and back last summer for the cost of 6 filters ($16 a piece).
The WVO system includes a 22 gallon coolant heated veggie tank, Davco 234+ (also coolant heated), a linehauler coolant heated in line veggie heater, and if that's not enough heat, I have a Veg-therm installed also. Also, it says, "Powered by Veggie" in white lettering on the back. Maybe you've seen me driving around.
The truck just had most of the suspension components both front and rear replaced, as well as new rear brakes and front brakes are only a year old. clutch hydraulic system also repleaced. Very dependable truck, just check the oil. 245,000miles. These engines will go for 400,000 easy.
I'm pretty firm on the price for as much money as I've put into it, including the veggie system.
* This item has been posted by-owner.
