How do i fix the oil leak in camshaft where pulley is attached? it happen
after i adjust the belt tensioner.
oil leak at camshaft of LD20
I don't know anything about the LD20II, as they were not fitted to anything in the US. Perhaps one of our NZ or AU members can help.
Generically, I'd carefully mark the cam belt and all sheaves, remove the belt, remove the camshaft sprocket, and replace the camshaft seal. But that's only a generic approach and does not take into account any peculiarity of the LD20II that may exist.
LD20 11
the part no for the oil seal from nissan is 13510 60U00
not a part that shows up in the US but you may get lucky
and have the dealer order one or get some one outside
the US to send you one thats how I got one
the lower seal is the same as a 240SX and the rear seal
is the same as 240SX Zcar and others
hope this helps glennjones376@hotmail.com
