Chev 350 overhaul
Posted: Thu Oct 25, 2007 5:57 pm
Thanks to Al, especially:
We got the old crank out with no trouble. I estimate the worst rod bearing had about .030" clearance. At the machine shop we were told the general wear was so bad that we needed a new crank, and that the rods needed reconditioning, which we went for.
Machinist said cam gear and chain were OK, and we kept the old oil pump since it had shown good pressure when cold.
New crank, rings & all bearings, seals, gaskets & labor came to $380 which we felt was reasonable, and it runs well now.
On the Ford Truck Enthusiasts site there's been discussion in the past about getting better economy on FE (360, 390) engines. A smaller carb, as small as 390CFM has been tried with good success, provides better mix at low speeds with sacrifice of power at higher RPM's, and I wonder if this approach would as well work for a Chev.
Ray Mac.
Ray Mac.
