Request for FSM info on leaf spring for pickup
Posted: Thu Mar 13, 2008 5:43 pm
I'm trying to get a line on leaf springs for the Maxima - and also "helper" type springs. I'm running to NLA for the Maxima springs and so am looking at other vehicles with similar springs. However, getting the functional specs for various vehicles has so far be hit/miss - ie. the the length, width, unloaded camber, and spring rates for any vehicle or for spring products are not directly available. I have found some info and measured various springs at the JY, but it's like pulling teeth.
I think the Nissan PU's may have similar springs to the Maxima, but I have not way to find the spring rate or the unloaded camber; 720 vehicle weight would also be nice. The suspension part of the FSM for the Maximas lists the rear spring info and similar info may be available for the 720's. If so I'd greatly appreciate a copy of that page (easiest for those w/a scanner) or a run down on the specs.
Important info is:
Length when flat (eye to eye); Width; unloaded camber; and...
For the maxima the loaded camber is listed along with a loaded weight per spring; that's how I get the average rate at rest. Hopefully the 720 FSM will have similar info.
Thanks.
Important info is:
Thanks.
