Another electrical issue
Posted: Thu Jun 05, 2008 6:07 pm
Hey,
Like this thread, http://nissandiesel.dyndns.org/viewtopic.php?t=1863, I figured I'd ask to see if anyone had pointers before diving into the harness. My glow plug system went kaput a few weeks ago so I put in an additional switch connected to a relay to bypass the glow plug system until I get around to fixing the stock system. Before it blew out, it would blow the fuse connected to it and I guess it just had enough of that. That's not my current problem, but I wanted to put that out there as background info.
Here are my current issues. The other night when coming in, I was on the highway coming home and getting off onto an exit, my dash gauges, egt gauge, voltmeter and oil pressure gauges all stopped working. The cluster and center oil and volt gauges are still illuminated, but do not work as well. Also, the key will not turn over the starter. When the gauges stopped working on the way home, I stopped to check the oil level just in case, and it was fine. Luckily the engine was warm enough that I was able to pop the clutch to start the engine, and after that I went straight home! All relays and fuses are fine, so now the search begins. Anyone have an idea of where to start?
Thanks,
David
Thanks,
David
