I need an FSM, can anybody help - out a fellow who's down on his luck ?
A freeze plug, right next to the IP started bleeding out. So I'll need the FSM for reference in replacing said plug. Also, PEP BOYS said there are 3 different sizes of "SAID PLUG" Any help is welcomed.
Thanks Guys
Freeze Plug Quit
- fergie
Casting plug R/R probably not covered in FSM anyway. Nothing here specialized or specific to the LD28. There are a few common methods, mostly depending on access. Behind the IP might be pretty tight access.
Try a screwdriver along the inner edge of the circle, hit w/ a hammer to try to get the plug to turn over in its hole (like a butterfly valve opening). Then pull/lever it out w/ pliers. Often, the plug gets mangled, but the cast iron block is much stronger.
Then measure the hole to determine the correct replacement. What is the material of the Pep Boys replacement?
Users browsing this forum: No registered users and 34 guests
