Safe turbo boost on LD28?
Kolatogari
Post by Kolatogari »
HI guy's, Since I canceled my plans for TD27t conversion on my Range Rover, I'm going for my old LD28 I had in my old Rangeie. Having all adaptors redy, i'm planing on putting a turbo on her. the turbo is from MMC 2,5diesel. What would be the safe vs power boost i could have? It was a little sluggy in my old one, but a small boost would make it nice. At least nicer than the Guttless Rover v8 :P
So. 6psi? 10psi? 8psi? 30psi? :twisted:
Guess i'll make the exoust manifold myself. Feel free to speak. :D
windsock
Re: Safe turbo boost on LD28?
Post by windsock »
Kolatogari wrote:HI guy's, Since I canceled my plans for TD27t conversion on my Range Rover, I'm going for my old LD28 I had in my old Rangeie. Having all adaptors redy, i'm planing on putting a turbo on her. the turbo is from MMC 2,5diesel. What would be the safe vs power boost i could have? It was a little sluggy in my old one, but a small boost would make it nice. At least nicer than the Guttless Rover v8 :P
Hi Kolatogari,
What is an MMC 2.5 diesel out of? A fella I know that does a bit of turbo work and calculations recommended I look for a T25 Turbo off the CA18DET Nissan motor and set the boost to no more than 9psi. I don't know where or how he calculated these but he seems to know what he is talking about in other situations.
If I was to go this route I would be tempted to give it a go as he said but I cannot find the ready money as yet to do this so it is on the list still...
I have built a 3 inch steel pipe intake/snorkel for mine (still have stock filter) and installed a 2.5 inch exhaust pipe keeping most as straight as I can under a Land Rover 110 chassis. Seems to assist easy breathing quite a lot better over stock.
Make sure you take pictures - didn't happen without pictures :wink:
Cheers,
Phil
windsock
Post by windsock »
Hi Kolatogari,
Cheers,
Phil
nogrip
Post by nogrip »
i take it thats a mitsubishi 2.5? as in a pajero or similar?
mine runs a l28 manifold and turbo and is at 7psi..
ld28t in a 81 transit van
