Page 1 of 1
Need help identifing this transmission
Posted: Sat Apr 10, 2010 3:42 pm
by cosmo2409
I imported twoTD27 engines approx 5 years ago. The TD27 diesels I have both came with auto trannies. These transmissions are both stamped with JATCO 46X10 as the model number on the tag. I cant find any specs on these trannies anywhere. They look like RE4Ro1A 4 speed automatics. Does anyone know anything about the TD27 auto trannies that were in medium duty european trucks. I assume these engines came out of the med duty trucks because of the water to air intercoolers that were mounted behind the cyl head. Only a cabstar or equivalent truck could have the space for this system.
Posted: Thu Apr 15, 2010 2:33 am
by davehoos
seen japanese urvan/caravan engines advertised on yahoo japan with the water heat exchanger.the auto is a givaway with the rear mount on top and a cable gear change,long dipstick.gear change ins controlled by the trans ECU.
the water tank runs around the back of the rocker cover as there is no room over the top,and looks like a marine engine.was interested in one as a conversion engine for holden commodore.
some TD27 urvan have a oval cast alloy pipe over the top.
E23/E24 wasnt fitted with turbo for australia.
Posted: Thu Apr 15, 2010 3:26 am
by cosmo2409
thanks for the reply. Everything you described makes it sound like a URVAN. I will look into the URVAN specs to see what this transmission is and how it compares to what I think it is. It sure looks like the RE4R01A we use here in the states.
Posted: Fri Apr 16, 2010 1:13 am
by davehoos
I recently looked at TD42 auto specs for a english gent.
unable to buy a diesel gearbox he fitted a TB42 petrol box.
the ecu changes the gears so the shift points was correct.
the parts numbers for most of the internals in the transmission was the same as the RB20DE skyline trans that is used by most of the performance cars.2 clutches had been upgraded-low and over run[from memory].
