My antenna stripped it's gears some time ago and in the course of fixing several minor anoyances I determined to disconnect it to stop the noise when it tried to raise or lower when the radio was turned on. The fuse says it controls the rear wiper as well and I kinda wanted that alive.
After taking a look behind the glove box I decided it didn't look promising. Instead I removed 4 screws from the inner fender and reached in and found the wires leading into the antenna motor. In order to cut them I had to remove the two mounting screws holding the motor to it's bracket and shift the motor slightly. This all was pretty easy but clipping the wires was still a bit of a juggling challenge; it took 3 or 4 minutes to get a small pair of dykes on the wires and make the cut. I left the ground wire which was separate from the power wires because I figured it might be needed for reception. No doubt it'll turn out there's an easy way, but it's done and I doubt the power antenna issue will ever be visited again on this car. Remounted the motor, buttoned up the inner fender. Takes about 20 minutes total.
Power antenna bad - retired
Users browsing this forum: No registered users and 55 guests
