Looking to buy sd33 fuel injector line, does not matter which of the 6 lines, as I will be using it for my OTC injector tester. Please e-mail me at dcampb18@sbcglobal.net
need sd33 fuel line
> end fitting
Duh! <g> Well...
Maybe a hydraulic shop could fab the lines, bends and all. Not sure, never tried to find this stuff. It'd cost more than pre-formed, of course. Could try googling and see what services are out there; if anything turns up then see if somebody does it locally. An IP shop would probably do the job or know who could; probably cost more that way. Could help if you had the original in semi decent shape.
There's enough diesels around. Seems there must be a way to get a high pressure IP line made up. I bet the whole thing is just cut and worked cold.
Duh! <g> Well...
