Info on putting SD22 in a KIA Sportage ??
kibbleking
Post by kibbleking »
Hello Everyone, Clancy here... have any of you folks put a nissan SD22 in a kia
sportage ?? Its on my wish list... I have a good SD22 and a kia with a bad engine.. The SD is out of an 1982 720 and the kia is a 1995.. Are the bell housing and manual transmission that fit the SD one piece or two ??
Are the bell housings that fit the gas engine the same as the ones that fit the diesel ??
Clancy
dn29626
Post by dn29626 »
Two piece.
The front of the front section (bell housing) either bolts to a diesel or a gasser but not both. The back of it will fit either tranny.
82 King Cab 2wd (nice)
82 Reg Cab (body damage)
Anderson , SC
Since Fall 2009
elminero67
Post by elminero67 »
Not trying to be negative, but that sounds like a very complex conversion for what youll end up with. If you can get it tthe SD22 to fit, the amount of labor spent fabricating mounts and fixing all of the wiring snafus would involve most of your weekends for a year...speaking from experience
sidevalve
measure twice, cut once.
Post by sidevalve »
go for it. make it work.
sportage was mazda based.
maybe an R2 might be easier.
if rear wheel drive only anything possible.
Arnold90
Re: Info on putting SD22 in a KIA Sportage ??
Post by Arnold90 »
kibbleking wrote:Hello Everyone, Clancy here... have any of you folks put a nissan SD22 in a kia
Clancy
hi there mate. have you tried looking for online information for that? Much better if you will go to a Kia auto dealer and shop because they might have the sufficient information that you need. thanks.
I hooked up my accelerator pedal in my car to my brake lights. I hit the gas, people behind me stop, and I'm gone. - Steven Wright
