correct fuel pre-filter for 9/81 sd22?
ive read here that the correct pre filter, which filters fuel from the tank and goes to the lift pump should have only a metal screen inside of it. there is a napa 3275 on there now. it is attached to the firewall with a factory bracket. it is clear plastic with a paper element inside. anyone have a good part number for the metal screen filter that goes in the same place? thanks
Users browsing this forum: Bing [Bot] and 0 guests
