Hi all,
I have the following problem and wonder if anyone can help.
Temp indicator on dash is not working.
I have put a potentiometer on the leads at the temp sensor side on the thermostat housing and when I turn the potentiometer the indicator does not move.
I would also like to know what the one wire sensor is next to the coolant sensor.
Is this a problem apart from the fact that I cannot see the temp?
Is it an easy task to change the temp. indicator on the dash?
Many thanks for any advice.
Nissan Vanette E 2.3D
