Does anyone know the part number or where to order one of the newer primer pumps for a bosch-kikki inline type pump?  The kind that you don't have to unscrew to prime?
I suspect I might be sucking air through the leaking old one.
Thanks!
						replacement primer pump
				charmalu
It`s a Bosch primer pump, they run around $20 depending where you source them. NAPA might have, or a VW performance shoP, the Diesel Rabbits probably used them.
These are a definite up grade over the one you have to unscrew. they eventually leak and suck air.
here is a listing.
http://www.pelicanparts.com/catalog/Sup ... .htm#item3
On this AZ site below, click on primer Pump.
http://www.autohausaz.com/search/group. ... id=22@Fuel
Do you have any PNP type Junk Yards> find a Mercedes Diesel in the 80`s and you most likely will find one on them.
Charlie
here is a listing.
Charlie
78 240D Mercedes $300 Parts?
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
86 Ford F250 6.9 Diesel 221K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
				charmalu
You are welcome.
These two sites are not the only place to purchase them.
Do a Google search on either part # each site lists and there are other seller that offer them..
On the Peachparts site the offer an adaptor with the Pump it the threads are larger than the threads on the pump. you will not need the adaptor for the Nissan or the older MB Diesels.
Note: This brand has a 16 mm threaded fitting, and comes with a~22 mm adapter. Can be used for models with either a 16 or 22~mm receptacle on the fuel pump.
I have grabbed a few in the PNP yards when Iam in there.
Charlie
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
Users browsing this forum: Google [Bot] and 128 guests
