Server power supply smoked; router LAN/WAN routing died
Posted: Sat May 27, 2006 12:35 am
At about 1400 PST Thursday, the server's power supply fried. I came home to the acrid smell of burnt electronics. Joni (the server for this site) had puked a cap in the power supply.
The PS' tag said 1999, and that server has been running continuously since 2002 at 100 CPU load (I ran the SETI client until a few months ago; thence I switched back to the Bovine Client). Though it's hand-picked hardware, it's still consumer-class bits with which I'd built it, so I'm OK with it dying every so often. I'd love to upgrade both the "main" boxes, but nearly everything would have to go, as Joni & Tori are both so old that they're still running PC133 RAM, 1.2Ghz Athlons. All SCSI too, in a whole pile of identical external drive cabinets. So "upgrading" them would really mean new boxes, and I'm not up for that -- yet.
At the same time as the PS failure, the cheesy ActionTec DSL router's LAN side died (10Mb/s connections it'll recognize and pass through to other local LAN connections, but nothing will traverse its internal bridge to the outside world, and no 100Mb/s connections work, which is most of my network, so it's toast). I've purchased a used NetGear router and installed it, and so far, so good.
The data seems to all be fine -- there were a couple of odd "last post" dates, but they corrected themselves after I posted/deleted a couple of junk msgs. The data is backed up nightly on another box that was unaffected (and I retain seven days worth of backups). Worst case is that Thursday's posts might be lost, and I doubt even that much. The server's data is probably fine, even without the backup.
So: new (used) power supply in Joni, the webserver; and new (used) DSL router that I hope won't require a power cycle every two days like the ActionTec did.
Oh, yeah: if anybody cares, the PS fan on my personal box is squalling too, now that I shut it off -- it was fine until then. So I have to pull it apart and lube it -- and clean out the dust. That means I'm typing this on computer number three, normally a test box only. Oh, well.
Meanwhile: expect some more outages this weekend. I have to do UPS battery maintenance which requires shutting down everything connected to the three UPSs -- which is pretty much everything. Every six months. It's time to pull the covers and fire up the vacuum too, the dust is thick after winter. So for this holiday weekend at least, expect the server to be unavailable periodically.
