97 UD 1800 only idles dies after first rev wont accelerate?
nihad
Post by nihad »
I own a 97 UD Nissan 1800 6.9 6cylinder turbo diesel it has the Zexel bosch pump and when i get it running it will idle but soon as I rev it the first time it dies right away.. I also cant drive it anywhere because of this problem? what do i need to check first i have plenty of diesel in the tanks. I have noticed if I rev it and keep spraying in starting fluid at the intake tube it will keep going.
Re: 97 UD 1800 only idles dies after first rev wont accelera
I believe that the fuel feed to the injection pump is impaired. I would check charging (lift) pump function & pressure, fuel filters, and for kinked or blocked fuel lines.
