Bleeding air from injector pump
waiwurri
Post by waiwurri »
Hi, Is there a blld screw on the injector pump on a ld28. I ran it out of fuel and are having trouble getting the air out of the system. Thanks Pete.
waiwurri
Re: Bleeding air from injector pump
Post by waiwurri »
Sorry that was ment to read bleed screw :D
BarryLaX
Post by BarryLaX »
Does anyone know where I can source a seal kit for the injector pump?
If there is a Bosch service center in your area, they can supply you with a seal kit (and most likely any other IP parts) if you tell them the numbers on the side of your IP.
