Oil Pressure
- TooManyIdeas
Oil Pressure
What is the normal oil pressure readings for an SD22 And where can i find a pressurized outlet. I see a plug just behind the heat exchanger, is that it? The goal is to add an actual oil guage and supplimental oil filter / pre-oiler setup.
85 Chevy Monte Carlo CL
90 Toyota Pickup -SOLD
05 Kia Spectra 5
02 Dodge Dakota Quadcab
-OOOOOOOOHHHHHHHHH YEAH!!!!!
05 Kia Spectra 5
Re: Oil Pressure
"Normal" assumes correct idle speed, oil in good condition, engine oil temperature equal to coolant temperature.TooManyIdeas wrote:What is the normal oil pressure readings for an SD22
So ... the correct oil pressure at normalized idle is 15-30 psi and the threshold pressure for the oil light is 8-11 psi.
The oil pressure idiot light switch is located on the block right side between the oil heat exchanger and the bottom edge of the block. Has a single wire connection.
Were I to bother with such a pressure gauge install, I would DEFINITLY use a 'Y' adaptor so as to retain the DPC pressure safety feature because the system will react in shutting down the engine MUCH sooner than your casual awareness of oil pressure loss.
Low Oil Pressure AutoShutOff feature
zen
Nissan manual gives 303-363kpa..thats about 42-52psi..it does not state at what rpm this is, so one has to assume its at 3000rpm with warm oil???
Anyway mine is 50 PSI cold at 2000rpm drops to 45ish when proper hot.
Idle, it's 30 PSI down to 19 proper hot.
(thats on an sd33t..but the manual i have covers them both(sd22 and sd33) and gives only one figure..anyway 22 and 33 are virtually identical)
turbo it
