Cylinder Liner Projection
dieselscout80
Post by dieselscout80 »
Has anyone ever seen shims to adjust the liner projection (0.02 - 0.09mm is the book #'s) if the liner is too low?
I know other diesels have them, but I have not sen a part # for them.
Diesel Scout
Knucklehead
Post by Knucklehead »
No. But that doesn't mean shims can't be used. Is there a problem?
'29 HD FD export model
dieselscout80
A guy on the Binder Bulletin got a rebuilt engine, but he found one liner is low.
Low cylinder liner results in coolant leak
Diesel Scout
Knucklehead
Not good. Time for customer service. If he's just got to deal with it I would pull out the liner and mike everything to determine the problem. I'd buy a new liner if the old one was short and I'd have a gasket shop cut an appropriate shim if the block fillister is too deep. Only the piston in the offending cylinder needs to be removed, and the whole operation can be done without pulling the motor.
dieselscout80
I was hoping to find a part # for the shims.
Diesel Scout
Knucklehead
Good luck.
Re: Cylinder Liner Projection
dieselscout80 wrote:Has anyone ever seen shims to adjust the liner projection (0.02 - 0.09mm is the book #'s) if the liner is too low?
You might also note: Press fit vs. slip fit replacement liners
