SD33 camshafts
Vehicles powered by Nissan six-cylinder SD diesel engines.
(EST)MahviaDeTyrk
SD33 camshafts
Post by (EST)MahviaDeTyrk »
Hi
Can enybody say - is the camshafts in SD33 and SD33T exactly same - or with some differences ?
Tracteur Tom
Post by Tracteur Tom »
Take a look at this thread.
There is a photo of a newspaper article on the changes Nissan made to the T version of the SD33. It states that the camshaft journals were enlarged - although I can't see why they did that ! Maybe there was some other problem Nissan fixed when they did the SD33T
So, in answer to your q, based on this, yes there is a difference.
(EST)MahviaDeTyrk
Tracteur Tom wrote:It states that the camshaft journals were enlarged
It means engine block's are different :roll:
I was hoping to find some info abouth cam lobe differences (Some non turbo engines intake and exhaust valves are open longet time or larger then turbo versions)
In the manuals is that the cam hight for limit when checking them is for the sd33 and the sd33t both 36,8mm
zen
Post by zen »
according to 1981 genuine nissan manuals they are the same..in every way..ie identical..
can't comment on later models...
turbo it
(EST)MahviaDeTyrk
There are three different ordering codes =
'79-'83 SD33 = 13001-90109 & 13001-90111
'83-... SD33 & SD33T = 13001-C8600
seems - some are same - some are different :roll:
zen
Post by zen »
more info needed then!!
as i have 3 sd33 engines circa 1980-87...
now the manuals i have are 1981..manual 1 sd22 and sd33..manual 2 sd33t supplement...both are genuine nissan books
both are very helpful giving all the camshaft timings and lob hight jounal dia etc...both are the same...
up to 1981 atleast..
turbo it
(EST)MahviaDeTyrk
1983 Nissan SD series engine manual pdf's available there http://forum.4x4.ee/viewtopic.php?t=1125
