Diagram to hook up 4N71B trans hoses to LD28 please
atk1
Post by atk1 »
Hi all, Im putting a LD28 and auto trans (4N71B) into a CF Bedford van. This is a very common transplant here in New Zealand. Does anyone have a diagram or picture of where all the hoses and wires from the trans go to the engine? Mainly the hoses but the whole lot would be great. Appreciate any help, cheers
asdex
Post by asdex »
Hi, I have the same motor and gearbox in my Transit so could trace any hoses etc you need to know.
Not sure what they are all for myself though.
Cheers
atk1
Post by atk1 »
Hey thanks, sorry about the late reply, we got all sorted except the wiring that stops you starting it in any gear, and also need to know the wiring to indicate what gear its in, cheers
nogrip
Post by nogrip »
in a similar situation...mine will only start in reverse,and have no reverse lights
ld28t in a 81 transit van
Glegor
Post by Glegor »
nogrip wrote:in a similar situation...mine will only start in reverse,and have no reverse lights
sounds like you got the starter interlock hooked up to the reverse light switch..
