Can anyone confirm that dipstick length? The one I have is 21" from the top of the cap (perhaps the 'shoulder'), 18.5" to the safe 19 & 3/16" to add. Its from a Ford
Oil dipstick length? And a ridiculous story later.
ipper
If anybody knows how to link to posts let me know. But I found on this forum that the dipstick on the sd22 is 21" from 'shoulder' to full. The dipstick in my SD22 is shorter than that.
- 1982Datsunsd22
- 1982Datsunsd22
I have 3 Datsun factory sd22 Diesel service manuals. 1 ,says" 6/-3/8ths quart of oil with filter change" The other 2 say 5/1/2 qt with oil filter change . I put in 5 1/2 quarts. Shows" Full"l on dip stick. 3 yrs no problem
Do not worry about 'Overfilling' [too much] However ,a Diesel can 'Run Away',If it sucks oil from the crankcase, and feeds the engine [way over filled], There are some "Runaway" Diesel vids on You Tube. I always keep something to cover the air intake If It goes wide open and will not shut off.
ipper
Yea it was over-filled so bad that oil was pouring out the breather tube when the motor was running. I had just been topping it off while I tried to figure out why it was leaking, turns out it was leaking because I was topping it off
Now I just have to find a new dipstick.
How would you stop a runaway motor running on lube oil? Cutoff the air somehow? Or would you have to stall it?
- 1982Datsunsd22
Diesel Fuel Rail got stuck Pump went wide open ,Diesels have no ignition
http://www.youtube.com/watch?v=3NRaqgab0_w
- 1982Datsunsd22
Users browsing this forum: Google [Bot] and 36 guests
