Cheers
Nissan 720 starter
shazz68
Nissan 720 starter
Hi there i have a nissan 720 series 1983 (NOT NAVARA) sd25 deisel motor. the starter motor is stuffed, and i cant get on to one in my area. does anyone know if any other starter is compatable? i am in Brisbane Aust.
Cheers
[/b]
Cheers
- Been thanked: 6 times
Depending on how your exhaust manifold is configured you may be able to get one from a fork lift dealer. I will see if I can find the link to the posting that I had put on with some issues that I had with mine.
Edit: Found it here:
http://nissandiesel.dyndns.org/viewtopi ... ht=starter
there is also another link within the above posting that Al put together with all kinds of starter info for the SD22 and AFAIK those will work on the SD25 as well. These are of course for use in the pickup trucks so not sure what your engine room configuration looks like.
Cant get your old one rebuilt ?
Good Luck
P
Good Luck
P
shazz68
manya
Hello guys My 1985 nissan 720 king cab won't start? sounds like battery but battery is good. No turn over power. What to do, what to do?
Brisbane Metal Recyclers
