Front springs
Dr. Jones
Front springs
Post by Dr. Jones »
Anyone know where I can get a set of front springs? I tried Rock Auto, Advanced and Autozone.
'82 Maxima Sedan x2
barkford
Parts
Post by barkford »
Dont know if an 1984 gen1 part would work on an earlier model year but maybe woth a look?
http://parts.nissanusa.com/nissanparts/ ... on=Keyword
Have you also thought about pull a part?
http://www.pullapart.com/
Dr. Jones
Post by Dr. Jones »
I try to stay away from the dealership but I do need a oil cooler gasket and are the only ones I can find that have them. I will ask them and see what they have. Hows the leaky Max doing? I used to just deal with it in mine but I have since needed to caulk it because my laptop hates it.
'82 Maxima Sedan x2
Do you have to have new ones, or will used ones (for LD28) do?
Mark Hartz still has the '81 Wagon in his backyard. You'd have to pay him to pull & ship the springs, but I'm pretty sure he'd do it. PM me if interested, or try calling him directly (his phone number is in the last post in that thread).
Dr. Jones
Post by Dr. Jones »
Thanks Al. I have a set of used ones, I just feel that they are probably worn out by now. Any thoughts of the longevity of this part?
I will definetly compile a list for Mark.
'82 Maxima Sedan x2
My Wagon had leafs in back, and they were definitely shot.
I do not think the coils are particularly robust, no, but I couldn't hazard a guess as to longevity.
Dr. Jones
Post by Dr. Jones »
Napa is showing a set, I might try them. I replaced the rears in both and ended up with dramatically different results. My manual sits high and is more likely to get loose than the automatic it sits a little low. I got the rears for the manual at autozone or advanced and the rears for the automatic from rock auto. I would get them from rock auto in the future. Before replacing the rears they were really bad. I can't see the fronts being much better although I don't have as uch bounce if the front as I did in the rear.
'82 Maxima Sedan x2
Duaneclark
front springs
Post by Duaneclark »
An old trick front alignment shops used, if one spring sags a little compared to the other, they would insert a rubber spacer in the coils, so both springs were at the same height.
Duane
