Don't know how I did it ....But I've lost turn signals, Hazard AND Windows. AND every time I put a new fuse in POW I'll also mention when it comes to electrical I have about as much "know how" as flying an F-16 (no prior military Xperirence)
HELP PLS
Lost turn signals, Hazard AND Windows !!
- fergie
You've got a dead short somewhere.
Not an easy job or one for a novice without A LOT of patience.
You will end up tracing the power back through the various "inoperable" circuits and try to pinpoint where you are losing power, or where the wire has grounded out. It might be easy and in an obvious place, or it might not be.
I would take a close visual inspection of the area under the hood, near the battery leads and see if you notice any visibly corroded or bad connections there. If one of the wires corroded through, it may be grounding on the frame, etc.
Ben Martin
fergie, please update your Profile (click on "Profile" at the top of any page) and edit your Signature to include your car. And adding something to your Location field would be helpful, too.
I need to know which year Maxima, in order to look at the correct wiring diagram, to give you some clues.
