Carimbo and I had a swell time Saturday, R&Ring the LD28 rear main seal. We began at the local car wash at about 9:30am and ended the next day at about 1:00am, with a break for lunch. Yeah, I'm slow.
Carimbo did almost all the work, I just provided the entertainment.
It was all pretty straightforward, with only a handful of, "Hmmmms".
Though the ATF was dark and smelly, the trans' pan was
extremely clean. Very odd.
RMS was very loose in the engine. When I inserted the hooked seal removal tool, the seal spun in the block! I popped it out with almost no force. We used a thin film of RTV on the OD when installing the new one.
Old seal:
I banished the aviary under the hood (bird chirping): the alternator belt was very loose and chirping. Carimbo's ride needs to have all four belts replaced. The three visible ones also have visible cracking.
The aftermarket trans mount we installed . . .
. . . did not seem to have the exhaust brace studs in precisely the same location as the old one, and I Dremel'd the mounting holes oval. It's possible that we didn't have the trans centered laterally the same as prior to disassembly, but I don't think that was the cause.
We replaced the torque converter seal and the extension housing seal while we had the trans out. The extension housing seal, though new, leaked a puddle approximately 10" in diameter during the flush procedure, which was quite a while after we started. Neither of use saw it until we'd started/stopped the engine a half-dozen times and were done flushing and ready to clean up. After removing all the oil, and driving it four miles, it does not seem to be leaking any more (?). Well, I saw
two drops after the four-mile drive. Carimbo will have to inspect it later, but at 1:30am Sunday we really didn't have a lot of options so he drove it home that way. I assume he'll report here his Monday findings.
Undercoating on the rear of the driveshaft
. You'd think that will all the warnings
I'd heard over the years about not getting undercoating on the driveshaft (upsets balance) that folks who
undercoat for a living would know better, or at least remove it with a solvent rag before it became cement, but apparently not.
Carimbo reported more drivetrain noise with new (aftermarket) trans mount, than old, soft OEM mount.
What else, Caxambu?
