I found new engine never been fired SD 22
phoneinstaller
Post by phoneinstaller »
I picked up a new engine from a person that has had it setting in his shop for years.
The engine has the flywheel and used clutch, 4 injectors and pump intake and ex manifolds
Alternator with vacuum pump it has the engine mounts on the block
It has the Altitude compensation that my 2 81 truck do not have.
It also has an EGR valve on it that my 81 trucks do not have.
It came with the diesel pump controller (DPC)
Items missing
Glow plugs (the person used them on his truck about 2 years ago)
The lines that go from injector to injector is broken and no washers for it.
no starter.
I am going to take the oil pan off and check to make sure on rest in side before I try to turn the engine over. If it does not look to good I will pull the head and check that all out.
It almost looks ready to put in to a truck right now with a little bit of cleaning.
hope $1200 was not to much
This engine will be for my 85 K/C 4X4 truck.
81 datsun diesel 2wd K/C
81 datsun diesel 2wd k/c
86.5 hard body 4X4 K/C For sale
85 720 k/c 4X4
I have 2 81 trucks
phoneinstaller
some more
85 720 k/c 4X4
I have 2 81 trucks
Re: I found new engine never been fired SD 22
phoneinstaller wrote:I picked up a new engine from a person that has had it setting in his shop for years.
WHAT A FIND!! :D
JESSE_DELEFF
hey there im jesse
Post by JESSE_DELEFF »
hello there hows thing going, i was viewing that new Nissan SD-22 that you have listed , do you still have it and would it be for sale if so?
thanks .. Jesse
JUST LOVE TO FIX THINGS
byrdlova
Post by byrdlova »
still have sd 22 engine?
we want to check our compression.
do you have adapter?
where do you check it at the glow plugs or injectors?
thanks byrdlova
dieseljunky
Post by dieseljunky »
I bought a 1982 2wd SD22 pickup for 125$$ the other day. All I need to do is replace a couple glow plugs! I guess I found a pretty good deal uh?
mago
SD 22 NISSAN diesel engine
Post by mago »
Hi.
Do you still have this engine? Quote.
If so, could you provide up date pictures?
Thanks,
Mago.
Glegor
Post by Glegor »
i believe he was just showing us his great find, not trying to sell it! lol..
anyways, FWIW, thats a CALI engine, its got EGR on it..
poppatello
Post by poppatello »
I'm looking to do a swap on my 84 Jeep Cj 7 but with the LD 28. I guess he isn't on anymore but I'm hoping he gets this email as I want to know how he likes this swap...
In a World Full of Copy Cats, Be an Original...
49ak
SD22
Post by 49ak »
I'm interested in your SD22 engine. Still got it? Please reply to:
edwardcahill@hotmail.com.
Thank you!
Ed
rustie
Post by rustie »
PinS...iss this SD22 still available? If so, my email is rustie66 'at' gmail.com
