In cases where there is a weak starter or battery it sometimes helps to unload the engine by sealing off the intake (put you hand tight over it - it should grab you good) and let the starter spin up to speed, then remove your hand. The starter has a much easier job of it w/no air in the cylinders and it gets some speed into the flywheel; when you "open" the intake it's like popping the clutch. I have done this a couple times w/big 6-cyl marine engines that didn't have enough battery left - it does work. But you need a remote start button or a 2nd person.
But listen to Al and do the nitty gritty stuff before throwing money at the engine. Without all the details in order no amount of the green stuff will get it going anyway.
SD23 fuel injector 'pump' head scratch.
- igaroot
Re: Rambler towed back to the house, no start UPDATE
Two batteries? More CCA? Better Starter? I hear denso's kick arse!Absolutely! Yes! It must crank fast, or game over.New battery at 760cca cranks good. Would slowish cranking be the whole problem?
Yes, there is an electric fuel pump in the tank that pumps in the on position. Works good.Did you address Philip's suggestion that perhaps this CAV IP needs an external fuel pump?
Reading up on the CAV system (in the generic Nissan SD22/23/25/33 Service Manual: non-vehicle specific, it covers agricultural/industrial setups), they show testing a mechanical lift pump, specs are 5.7-8.0 PSI feed pressure to the IP.
Good to know. I might put a gauge on the fuel delivery.
Yesterday, when I had the injector lines disconnected I put paper towels under them. There was a 4" circle of fuel under each line after cranking for ~30sec.
I'll try with the spring loaded. Wasn't loaded when it started last time. Worth a try though.
Wow you have eyes like a hawk(lit and fig)! I noticed this yesterday. I did not confirm voltage, at that time. Definitely worth checking out.. . . plus what the manual is calling an "autostop solenoid", located perhaps at the bottom rear of the IP. Looking at your single IP pic, where does that orange wire go?
Does not appear to be the oil pressure switch. If it connects to a solenoid on the IP, perhaps you do not have 12v to it while cranking?
If me glow plug circuit is working properly (I know, I need to get the multimeter from work), I think my main focus should be on cranking the engine faster (jump). Shut offs at the IP will be investigated, and perhaps the pressure from the lift pump in the tank.
Good stuff Al. Thank you. Still want to buy it?
"Finding the occasional straw of truth awash in a great ocean of confusion and bamboozle requires intelligence, vigilance, dedication and courage without which we risk becoming a nation of suckers, up for grabs by the next charlatan who comes along." - Carl Sagan
1959 Rambler w/ SD23
1993 6.2 GMC Sierra K2500 w/ 20A converter
1998 VW TDI Jetta
1998 VW TDI Jetta
- igaroot
oxygen intake refusal
Rufus, "unloading" the engine may be just the thing for this little boat pusher.rlaggren wrote:In cases where there is a weak starter or battery it sometimes helps to unload the engine by sealing off the intake...
1998 VW TDI Jetta
1998 VW TDI Jetta
It's hard to advise without hearing it, but generically you want a cranking RPM above 200 RPM on a small diesel to reliably light it off. That's 3+ revs per second.igaroot wrote:Two batteries? More CCA? Better Starter? I hear denso's kick arse!
Is the battery a "good" one? I like Interstate and detest Exide. The condition of the terminals can make a big difference too, with the bolt-on temporary terminals often having a fairly high resistance at the amperage a diesel draws to crank.
These are designed for temporary use only, until a real terminal can be swedged on to your cable. The SD OEM cables as installed in the 720 PUs are especially heavy (0 gauge or better).
That may not be enough -- I would think that a bit more fuel than that after 30 seconds, would stain your paper towel.Yesterday, when I had the injector lines disconnected I put paper towels under them. There was a 4" circle of fuel under each line after cranking for ~30sec.
The manual I have is not clear on which direction is "RUN" and which is "STOP". Of course, almost none of us know anything about the CAV IP.I'll try with the spring loaded. Wasn't loaded when it started last time.
If the GPs are the "slow" GPs, they are very tolerant of leaving them on too long. But if they are the alter "fast" GPs, they can be burned out fairly easily. If you have one out again, buff off the side and write down the number and post it, we can tell you which control system is needed for them.If me glow plug circuit is working properly (I know, I need to get the multimeter from work) . . .
Jump cables often can't carry enough current to help start a diesel that isn't in perfect tune. Better to sort out your cable issue (if you have one) and borrow a good battery, etc.. . . I think my main focus should be on cranking the engine faster (jump).
Yes. Maybe. It's not at the top of my list, but it's the right colorGood stuff Al. Thank you. Still want to buy it?
- igaroot
asavage wrote:Is the battery a "good" one? I like Interstate and detest Exide. The condition of the terminals can make a big difference too, with the bolt-on temporary terminals often having a fairly high resistance at the amperage a diesel draws to crank.
The battery is a Platinum Kragen genericish model 96. Where would one find a good swedger? Can I do it myself? Does it involve melting lead?
They are NGKs and appear original. I'll post when I check um' out again.asavage wrote: If the GPs are the "slow" GPs, they are very tolerant of leaving them on too long. But if they are the alter "fast" GPs, they can be burned out fairly easily. If you have one out again, buff off the side and write down the number and post it, we can tell you which control system is needed for them.
1998 VW TDI Jetta
1998 VW TDI Jetta
While you can buy the swedging tool, it isn't practical to buy unless you do a lot of it. I don't own one, for example. I have a local auto electric place do my cable work.igaroot wrote:Where would one find a good swedger? Can I do it myself? Does it involve melting lead?
Member dieseldorf mentioned solder-in-place terminals in this post.
- igaroot
Glow plug identification and catoragorization
Checked the GPs today, or at least the one in front. All four appear to be the same vintage.
NGK model #8453 no match in the following thread.
SD2X Glowplug information thread
Would be nice to know if I can keep em' on for 20sec+ ie. non quick start.
I really need to get the multimeter. I have no way of knowing if my direct GP circuit is working. Cold combustion chambers I fear.
The shut off solenoid at the IP is connected to the ignition at the acc. position. The same as the lift pump in the fuel tank. Multimeter would confirm voltage.
My battery's sticker indicates 770cca. Cable swedging is in my future.[/u]
1998 VW TDI Jetta
1998 VW TDI Jetta
