My Find
billyg
My Find
Post by billyg »
1983 720 King Cab with 96K showing when I got it, original owner said half of that came behind an RV, Sat for 8 years with the second owner who knew absolutely nothing about diesel's. After roughly 2.5 years of effort when I could squeeze shop time in, it's back on the road.
http://i243.photobucket.com/albums/ff39 ... het003.jpg
http://i243.photobucket.com/albums/ff39 ... het004.jpg
http://i243.photobucket.com/albums/ff39 ... het005.jpg
http://i243.photobucket.com/albums/ff39 ... het006.jpg
http://i243.photobucket.com/albums/ff39 ... het002.jpg
http://i243.photobucket.com/albums/ff39 ... het007.jpg
Only significant rusty spots are here:
http://i243.photobucket.com/albums/ff39 ... het009.jpg
http://i243.photobucket.com/albums/ff39 ... het010.jpg
"Let me control a nations currency and I care not who makes the laws" N.M Rothschild
That's an awfully nice looking ride. You don't see older datsun / nissans that look like that very often!
TooManyIdeas
Post by TooManyIdeas »
I have the exact same truck color and everything (only much uglier). I like your wheel size could you tell me what your tire size is?
85 Chevy Monte Carlo CL
90 Toyota Pickup -SOLD
05 Kia Spectra 5
02 Dodge Dakota Quadcab
-OOOOOOOOHHHHHHHHH YEAH!!!!!
billyg
tire size
Post by billyg »
is P205/75R14, too big actually but that's what was on it when I got it so I went back with that, makes steering more difficult though, and it rubs that flap behind the tire at a certain point. had a tough time balancing the tires/wheels, I think because of the way the lugs clamp up. the factory nuts are self-centering, these aren't, and it nearly drove me nuts trying to get it right. I've got a set of factory rims that I will go back with once i wear these out - or before if they start trouble again.
redmondjp
Post by redmondjp »
Nice find! That is one straight body. :D
Yes, I am anal about using factory wheels that are hub-centric, as just about every vehicle that I have ever had which had aftermarket wheels on it didn't ride smooth (with one uni-lug slotted mag wheel actually rubbing on the brake caliper when it would shift a bit).
You may look into getting hub adapters, which are basically molded plastic rings that will center the wheel on the hub, or somebody can make some for you on a metal lathe if you have any connections (just make sure to use a very light coating of anti-sieze on them if you get metal ones made).
Users browsing this forum: No registered users and 44 guests
