Anyone know what the redline or normal rpm range of the LD20II turbo? I have several gearing options would like to operate this in the proper rpm range.
Thanks
LD20II RPM?
manual shows IP tuning up to 5500 rpm.
my cars have stuggled with obvious fuel cut back around 4000 in direct drive down hill.
vanette/largo runs around 4.11 final drive with 14 inch wheels.
910 in japan uses around 3.7:1
i had a 3.45 with overdrive trans in a 1250 KG car and found this to be good on level ground.fuel economy not as good when overdrive----just the noise.
Users browsing this forum: Bing [Bot] and 4 guests
