Engine block's
(EST)MahviaDeTyrk
Engine block's
Post by (EST)MahviaDeTyrk »
Are the engine blocks SD22, SD23, SD25 same or different ?
similar but very different.
SD22 only has 3 main bearings.
(EST)MahviaDeTyrk
Is there a possibility to fit SD25 cilinder liners into SD22 engine block ?
What's SD25 and SD22 cylinder liners outer diameter or wall thickness ?
Seems piston pin's and piston connecting rods are same - but someone has tried to make SD25 from SD22- just with bore enlargening ?
The bore of a SD25 is 89 MM and the stroke is 100 MM. The FSM sates the cylinder bore of the block as 92 - 92.020mm and that the bore of the liner should be 89.00mm to a max of 89.030 (depending on what grade of liner you install, they list 3) I do not have a FSM for a SD22 but perhaps someone out there with one can see what the block diameter is for one of those. Also! The block height for a SD 25 is 268mm +/- 0.002mm. That measurement is taken from the bolting surface of the upper main bearing to the top of the block. The piston pin hole for an SD25 is 25.992 - 26.00. I am not certain what the SD22 pin hole is and, even if the stroke of both engines are the same that may be a point to consider as well. As it appears that the liner thickness is only 3mm (approx) I doubt very much that the block bores are the same between the two engines. ,,,,,,,,,,, IMO. :roll: I am sure that I will be corrected if I am mistaken. :wink:
Hope this helps.
(EST)MahviaDeTyrk
plenzen wrote:The piston pin hole for an SD25 is 25.992 - 26.00. I am not certain what the SD22 pin hole is and, even if the stroke of both engines are the same that may be a point to consider as well.
Pin holes are same and strole is same and connecting rods are same
