My Brother in laws 1983 gasser with 180,000 miles cuts off after idleing for a couple of min then its hard to start.
We just performed a tune up including cap rotor spark plugs fuel filter.We also cleaned all connectors on the fuel system and anyone we could find.throtle body and all hoses cleaned.We even did seafoam through the brake booster vacuume line.
Help what can this be? The maxima just completed a New York to California California to Miami run. It did have symptons in Houston when he got off the highway.But when the car is running at highway speeds it runs great.Only when it completes a 3 to 5 min idle it starts to hesitate and loose power and cut off.Then its a little hard to start but starts right up.
What should I Look For?
thanks
Bill
1983 maxima gasser cuts off after 5 min of idle help?
- Been thanked: 1 time
Does it then run fine or does it continue to cut out at low engine speed? IOW, does the problem occur once a day and then you're OK until tomorrow, does it happen every time you try to start and then once you get it going it's all fine, or is the car undriveable because it always cuts out at low revs?Only when it completes a 3 to 5 min idle it starts to hesitate and loose power and cut off.Then its a little hard to start but starts right up.
Although some of us here have a fair amount of experience w/gassers (of various types), the engines discussed on the board are really all diesel. One of our regular participants does drive a gasser and he may chime in and the rest will do our best; however, you may be able to fine better informed groups for your car. In particular the vintage Z crowd probably has far more info on your engine - you just have to survive the cat-calls regarding your "old folk's wheels". <g>
Cheers, Rufus
I think that either your idle air tract is clogged or the mass airflow sensor is faulty. Also, check all rubber hoses on the intake system, even all of the vacuum lines, and especially the big one that runs from the throttle body to air cleaner. It may be leaking too much as heat soak from idling sets in.
Try removing, inspecting, and cleaning (if nessecary) all the hoses in the photo below, and the idle control valve, but dont turn the big flathead screw that is on it, but if you do, mark it and count the threads turned and reset it back to where it was orginally. Im guessing that debris and deposits are clogging the plumbing so the engine has no air for idling properly. If you find that its grungy I would recommend replacing the pcv valve. A clogged pcv valve can puke alot of grunge into the intake system through the top hose that runs from the valve cover to intake bellow.
Click to enlarge
If that dosent work, I can look up the resistance readings on the MAF for testing
Click to enlarge
- Has thanked: 3 times
Yup, the ignition Ignitor is infamous for dying when hot. At idle, you have no airflow across it and the heat from the dist body heats up the Ignitor. Usually have to let it sit a bit to restart it though.
I'd sure like to dbl-check the fuel pressure before condemning the Ignitor though. If you can borrow a fuel injection pressure gauge, connect it and tape it to one side, then reproduce the symptom and make sure you have sufficient fuel pressure when it dies.
