I am in South Carolina. Are the parts to rebuild SD22 injectors available?
What source should i get the parts from?
My truck cranks mean below freezing (glow plugs tested good).I want to have the injectors rebuilt.
I suspect SD 22,25, or 33 can be used, is that correct?
SD22 injectors-rebuilders
I am not certain if the 22, 25 ,and 33 injectors are the same or not but diesel injectors are typically sent to a diesel fuel service center as there is specialized equipment used to rebuild them. These service centers will no doubt have the parts that are/may be required to fix them. With this being said you may want to ask them to up the "break point" to around 1900 to 2200 psi. This will assist in cold starting. HTH
P
P
