Pneumatic Governor Diaphragm
dieseljunky
Post by dieseljunky »
Did some reading on here and realized why my SD22 was smoking black as coal and idling very fast. Original leather diaphragm. Ordering a new one so hopefully that will fix my issues.
Just thought I would share with you guys. Sorry the pic is so big.
Does Anyone know where else to order one of these besides http://www.swdiesel.com?
[img][img]http://i840.photobucket.com/albums/zz32 ... 0_1573.jpg[/img][/img]
Thanks for posting. Are the edges torn or is just cut out that way?
dieseljunky
Well, the edges are pretty smooth. Starting to slightly crack around the edges. That one spot had a bad tear in it for some reason or another. If the diaphragm was a clock the big tear there is about 10 o'clock. Hopefully that helps you.
Yes, that's what I was looking at.
I think I read here a long time ago from an aussie that rebuilt these with inner tube rubber. But maybe that was something else - like a fuel pump. But a thought in case you're up against it somehow.
Cheers, Rufus
Post by Nissan_Ranger »
There was some considerable discussion with respect to the diaphragm, correct fluids, and the process of R & R. I mentioned I'd put power steering fluid into the governor housing of my SD. That has been in place since 2004 and still no difficulties to date...
N_R
dieseljunky
Well, this time I went with the easy route and ordered a new diaphragm from
swdiesel. It was 42$ shipped to my door. 12$ of that was in shipping. So I guess that is not to bad. I might try to experiment with the old one and see if I can make a new one.
Do you guys think I should put some kind of lubricant or softener on the new diaphragm before I put it in?
ecomike
Post by ecomike »
Straight old style dyno motor oil should work just fine. I used an old style crude oil based vacuum pump oil on mine about 4 years ago, and ever since, with no problem. I think the trick is to use a non-volatile, non-biodegradable oil, one that does not evaporate at high temps and high vacuums, and one that does not cook at high temps. In a pinch, I would use 40 weight motor oil, the old non-synthetics.
Mike
